Thread: Haze in LAX Spotting Trip Photos
    Nov 2011
    I am sure everyone is battling the annoying atmosphere haze in your photos from LAX this past weekend. I wanted to share a quick tip that I use to get rid of it - or highly minimize it. You can add a ton of contrast or add blacks, but that will blow out your shadows and cause gradient banding. When editing the photo, just add normal contrast you would use and a pinch of black in Camera Raw. When you're in Photoshop do the following.
    Duplicate layer
    Add a curves layer adjustment
    Change blending mode to Soft Light
    Adjust the opacity until you see a desirable result
    Below are a couple of before and after images.
    Timothy LaBranche
    See my photos on:
    Timothy LaBranche.com
    Flickr
    JetPhotos.net
    Thanks for the tip Tim! I am sure the ground shots I took at LAX will have heat haze galore. So I will give it a try using your post processing technique. Thanks!
    Senior Member Aviation.High.Guy's Avatar
    Dec 2012
    Thanks. Great tip for NYC haze too!!
    -Don B.
    Senior Member JDANDO's Avatar
    Oct 2009
    KMSP, KANE
    There was haze on Monday as well. I will have to give your method a try!
    Jeremy in Minnesota
    My pictures on jp.net
    Great tip Tim, and I am sure you meant to say "crush" your shadows and "blow" your whites
    ...seriously though, since this is a technical post... Since we are only manipulating data in digital, the terms come from what is happening to the data... blacks get crushed because the data is literally gone, nothing zip zilch... the whites blow out because there is too much data... in 8 bits, we get to 255 and then bam, too much.
    Tim, do you like the Curves tool as much as do? I consider it a scalpel in the world of the Brightness/Contrast Machete... lol.
