Results 1 to 15 of 29
Thread: Northeast Weatherpocalypse Discussion 7/26/12
    Flying to or from the northeast today? Expect delays. Lots of them. Widespread thunderstorms will continue to wreak havoc through Thursday.
    As of 12:30 PM ET...
    These are delay programs for flights arriving at the listed airports. For example, if you are flying to LGA, your flight will be held at its origin for 89 minutes.
    FCAA08 is an imaginary line that runs basically east to west across the middle of Virginia. If your flight has to cross that line northbound, i.e. you're flying FLL-DCA, your flight will be held at FLL for 13 minutes.
    FCAOB1 is an imaginary line that runs roughly north to south from Lake Erie through western New York, Pennsylvania and into West Virginia. If your flight has to cross that line eastbound, i.e. LAX-JFK, your flight will be held at LAX for 104 minutes.
    Note that these are all average times, and your flight could be delayed further by other factors.
    Some airlines are waiving change fees for northeast travel today, including JetBlue and Air Canada.
    Stay tuned...
    CYOW - Ottawa, Canada
    YOW spotter checking in here. Feel free to divert here ;)
    The "moderate" threat of severe weather has now moved to include nearly all of Long Island.
    As of now, the next wave of storms will strike NYC ater 7pm, echo tops being as high at 50,000ft or more.
    One of the models shows a bow-shaped supercell/derecho hitting NYC around 10pm. Or it could fizzle.
    Seems that today's high temps are going to be quite a bit lower than originally forecast so that might work in our favor. But there are storms popping in western PA and NY now with tornadoes.
    It looks like the worst of it is going to be up North in CT.
    Looks like Steve is getting what he deserves.
    It does look like it is going to be an interesting night. Stay safe everyone.
    As if the approaching storm that already has tornadoes was not enough, cold fronts (blue) or squall lines (the red dash & dots) that hit and converge with both a trough (orange dashes) and a warm front (red line) usually creates very ripe conditions for even more tornadoes in the armpit or "pocket" of the convergence. The above prognostic chart shows that as being... New York City. Hopefully that dry line moves and cooling evening air weakens it slightly, but we (I) won't know for a bit yet.
    Looking at the new SPC products:
    T-Storm Chance: Moderate
    Tornado Chance: Between 2-5%
    Winds (50 knots or higher): 45% (30% for eastern tip of LI)
    Hail: 15%
    For those of you with scanners have your local SKYWARN frequency programmed so you can hear what is going on around you. Also have NOAA All Hazards programmed, 162.550MHz (KWO35 - NYC), 162.475MHz (WXM80- Riverhead,NY).
    Senior Member Cary's Avatar
    I assume Enterprise's inflato-dome was built to withstand extreme weather?
    Quote Originally Posted by Cary View Post
    One would think that had been taken into account, I hope...
    Standby as the Intrepid may soon have a new underwater attraction...
    seriously, got a meteorologic question Phil. Is the storm is coming from the west and as it passes over NYC, do all the tall buildings have any sort of a "buffering" or lessening effect of winds coming from the north? In other words, do the buildinsg of manhattan act as a bit of a wall or barrier and soften the winds that hit ares just east of manhattan, such as rossevet island and queens/LIC?
    Just talked with a coworker who is flying back to CLT this evening (US out of LGA, I think) and his 6:59 departure has already been delayed to 9pm...he's thinking about spending another night in NYC.
    I just checked and all I see is clear blue skies...so you all be sure to send those diverting heavies down my way please, I'll be waiting on the back deck thanks
    I read that the dome was damaged by last week's pre-opening storm, but not sure if it was from hail, wind, lightning, etc. If today's storms hold together, they will be worse than that.
    May 2012
    First go around is official. Delta 216 pulled up going for 22left, right in front of me. I happened to be going to see where "the mounds" we're for the first time, on the way to an appointment out on long island. A heavy suddenly pulled up just as I was turning around to get on my way. Wind shear and heavy turbulence at approx 100 feet was the cause. They're switching to the fours possibly for the night, depending on where these winds force things.
    First time I've seen a go around from that close. I hope everyone's ok...but that was pretty damned impressive to see.
