Originally Posted by
Zee71
TJ..........nice variety! Depending on conditions, I may sometimes walk onto the bridge to get a little closer to the departing aircraft for some of my shots. Also, check your metering and white balance settings, you'll have to adjust those some times depending on conditions. For some of those morning departures off runway 31L from HoBe you probably want to wait until the aircraft are either near or crossing the bridge for the best light, otherwise you can get images that are under exposed, etc.
Yeah.........it took me a while too to finally get a nice clean shot of the TACA. I've tried from various locations, but heat haze killed most of my shots.
Typically, if they are using the 31s in the morning you'll get a variety of heavies and cargo aircraft departing off 31L.
