Results 1 to 15 of 15
Thread: Inside SCA905
    Senior Member fk6065's Avatar
    Oct 2008
    Inside SCA905
    I had the opportunity to visit SCA905 while she was here and got the privledge of getting inside the aircraft. The NASA SCA crew were first class gentlemen.
    One the side of the aircraft they have the Shuttles that they transpoted marked.
    Inside the cockpit
    This image is mounted on the flight deck right under the cockpit where additional passengers would sit.
    Inside the aircaft looking towards the rear of the plane directly under where the shuttle is mounted
    Control sticks
    The "Black Box"
    Inside rear tail section
    Looking up from insidethe aircraft at the landing gear door of the shuttle. It is a mix of original tiles and replacement styrofoam tiles. The numbered ones are original.
    Each heat shield tile was numbered and had to be put back in the exact same spot if they came loose or fell off.
    http://fredkopf.smugmug.com
    Senior Member JDANDO's Avatar
    Oct 2009
    KMSP, KANE
    Holy moly!!!! That is a fabulous opportunity. Thanks for sharing the shots!
    Jeremy in Minnesota
    My pictures on jp.net
    Apr 2012
    Glad to see that you got inside her Fred, great shots of a rare bird!
    May 2006
    Fred, These are awesome! Thanks for sharing them.
    Wow Fred!
    Great opportunity to have before they scrap the SCA's
    Oh my, that's a sweet op, Fred. Nice going...
    Does that last "marking" on the outside of the SCA say Phantom Ray - 2 Ferry Flights? ?
    Jul 2008
    Very cool! Great shots Fred!
    Oct 2008
    Quote Originally Posted by puckstopper55 View Post
    Yes it does. The crew was telling me that they had done a few UAV test flights for Boeing and were hoping that they would be able to continue to use the aircraft for these type of missions after thei last shuttle mission with Endeavor this fall. If not, as the crew said, 905 will be "Going over the fence" for good.
    Oct 2008
    And thanks for the compliments.
    Awesomeness!
    Curious...how were you able to see the bottom of the shuttle from inside the aircraft? Is there a window in the ceiling or a door?
    Oct 2008
    There is a small hatch in the top of the pilots cabin, where they flew the flag out of when it arrived that gave you a great view of the nose of the shuttle. The shots above were taken from one of the doors in the cabin that they opened up over the wing that the crew opened so we could see the landing gear bay and the marked tiles. It seems there are more fake tiles than real tiles on Enterprise.
    Neat, thanks.
    Mar 2012
    Houston, Texas
    I remember seeing NASA 905 flying over my house in the Seattle area when Boeing was modifying it for the shuttle test mission. It would be nice if that aircraft could go to a museum too.
