Yongnuo RF-603C radio poppers
Poppin on a budget
I love off camera flash work and purchased 2 expensive flashes, the Sigma EF-500 DG Super and the Sigma EF-530 DG Super because of the off camera optical flash Capability. Optical means that when 1 flash fires from any camera, the Sigmas' will fire. It sucks when your at a wedding and you have it set to full power, it will take 7-8 seconds before the flash is charged enough before they are ready to fire. If I keep one flash on the camera, I can trigger the other flash without doing it where everyone is using my flash (But then I only have 1 flash off camera)
Downside 2 of my sigmas'
Line of site and distance. During the day it needs to be within 30 feet for it to work, your always having issues with distance but it did the job, Just not great. Line of site, I am always struggling with making sure the red face was facing my camera because just a little off and the flashes would not fire, the further away, the bigger the issue.
Shot triggered Optically from my 40D
Pocket Wizards....the Cadillac of radio popper's.... If you have these you can tune to the right channel at MSG and fire a dozen strobes in the ceiling and strobe the entire area. This is what the pros use but they are like $250 a piece!!!! I would need one transmitter and 2 receivers and that is WAY over my budget. They are pretty reliable but because of the frequencies they work at the flash cap and charging may interfere with the actual shot leading to misfires. The misfires are not many and from what I have had and read it is about 1 loss in 25 popps but that also is VERY dependent on the equipment being used. The Pocket wizards are also TTL and that is a big plus.
While shooting long exposure and using painting with light will not work with radio poppers like above, the photo below shows where your popping a subject, this is the perfect use and will same me LOTS of frustration due to Sigma's line of sight limitations. Also will allow $60 flashes to replace my $250 sigmas!!!
EL CHEAPO - Yongnuo RF-603C radio poppers Quantity 4 for $65.00
Positive
VERY INEXPENSIVE
Can use as a wireless trigger (very long range trigger)
Each RF-603 can be Master, Slave or wireless trigger with included wire
VERY LONG RANGE 100 feet plus, some people have claimed up to 800 Feet but I do not believe it.
Negitive
No Lock for hotshoe (Cheap fix $5 lock on Ebay)
No TTL transmission
So far I am in love, Distance seems limitless, I can walk a block away and move my flashes...move just out of frame and click the trigger off, then move my flashes and pop it again and again and again! Sure, No TTL but from a block away I really am not going to use TTL as well! I can not wait for Hockey this weekend! This is going to rock!
I have 4, two for flashes, one for camera and one for a remote trigger. All four cost me $60 and 1 pocket wizard is $250!!!
