Thread: Design Your Own 787 Dreamliner
    I took a stab at a simple yet radical paint job... all of you should post here your own designs :-)
    >>Asphalt Red<<
    Somehow it works in Internet Explorer but not in Firefox (the link to my design that is... ) and in FF it takes you to the main page... in IE it redirects to my design. If you search, it is titled "Asphalt Red"
    Works in FF for me.
    Apr 2010
    Cambridge, MA
    I'm rubbish at this. Can't get the text to stick.
    It's a rubbish site.
    I tried playing with that site, but I agree, it's not easy to work with. I found a 787 template on line, and put this together instead...
    Absolutely it is not easy to use at all... trick to get things to stick. Make sure you use the tip of your mouse to click on the spot you want things to stick to... NOT the actual logo or text.... the log or text lags behind the click point so if you have it laid down where you want it, the pointer is usually floating in sky. So, click first and then slide it around to where you want it.
    And I figured out the issue with FF and what not, that's why it works now. Apparently this forum automatically tries to parse the URL and replace high order ASCII by their escape code... so replacing it with the actual char fixed it for FF.
    Works easy on Safari, on a Mac ;) Took a stab at it.....
    Now that I have a winning livery, time to find some investors, routes and start flying
    And a few HoBe bank shots!!
    BANK, baby , BANK!!!
    In da face!!
    ....you've just witnessed what happens when mirrodie is tired and wifey is watching holiday Michael Buble specials....
    Nov 2011
    cool design.. im using a firefox, my bad. i want to download ie as soon as possible now..
