Results 1 to 4 of 4
Thread: Everything You Ever Wanted to Know About Engine Cowlings
    Senior Member NYCA News's Avatar
    Jul 2010
    Post Everything You Ever Wanted to Know About Engine Cowlings
    NYCAviation:
    Rarely is much attention paid to one of the most important design aspects of modern jet engines: The cowlings.
    [Click to Read Full Article]
    Dec 2010
    Nashville, TN
    Good read!
    Steve Furst
    View my work @
    Furst Edition Photography
    JetPhotos.net
    To add the the 190 and 737 engine and why that have those different shapes... The reasoning behind that is because on most jet engines the accessory drives and whatnot are mounted on the bottom of the engine... Because of the height of the main gear on the 737 and the hight of the nose gear on the 190 this wasnt possible for maintaining min ground clearnce so they had to move the accessory drives to the side of the engines in the nacelles.
    Feb 2011
    brooklyn
    Here is a great video showing the sucker doors in action. They open at low airspeeds and high power settings:
    http://www.youtube.com/watch?v=ILXZP...eature=related
    The JT3-C engines, as pictured in the "junk" engine are turbojets. The first turbofans on the 707 were the Rolls Royce Conway engines, but the bypass was minimal. When the JT3-D turbofans came out, they were labeled "high bypass" fans, which at the time was true, but is rather laughable now. The "vacuum" effect of the fan pulled air from all directions so strongly, that a new cowling was required. A blunt smooth large cowl was required, which at the time wasn't possible with the known aerodynamics. The solution was the sucker doors which allowed air flowing forward around the engine cowling to bypass the lip.
