Results 1 to 6 of 6
Thread: Delta Connection CRJ Lands With Broken Landing Gear
    Senior Member NYCA News's Avatar
    Jul 2010
    Post Delta Connection CRJ Lands With Broken Landing Gear
    NYCAviation:
    A Delta Connection jet has landed at JFK Airport in New York without its right main landing gear. Emergency evacuation chutes were seen deployed from the Bombardier CRJ on Runway 31R. First responders were seen enroute. Developing…
    [Click to Read Full Article]
    NLovis
    Guest
    It is indeed a CRJ on 31R. The right main landing gear did not deploy and everybody is accounted for. 31R remains closed currently and it is causing plenty of disruptions though not as bad as it was earlier. If I get some good shots I will post them up.
    JFK
    The a/c was taken off the active this morning at aroung 6;45
    "You above all"
    Came across this video of the CRJ touching down by a passenager that was on the flight from ABC News.
    http://abclocal.go.com/wabc/video?id=7689827
    WOW! Great job by a great pilot!
    Senior Member Ari707's Avatar
    Oct 2005
    West Hempstead, NY
    Seems a SkyWest CRJ-200 landed last night with the left gear up. "CRJ200 incident at Skywest last night. Fortunately no injuries. Left landing gear up. Cause still unknown; under investigation. " copied from Bombardier's twitter feed.
    http://www.msnbc.msn.com/id/39409196...-milwaukee_wi/
