Results 1 to 6 of 6
Thread: Photoshop CS5
    Photoshop CS5
    Content Aware.... is anyone else completely stunned on how well this works as I am. The video is crap compared to how much fun I am having....OMG this is the first photoshop in a LONG time that makes upgrading well worth it! WOW this is insane!!!
    some one give me a photo!!! ahahah
    Re: Photoshop CS5
    We talked about this when this video first came out. Does it really work as well as the video shows?
    Re: Photoshop CS5
    Yes Matt - it does - I have played with removing bushes from pictures, I've removed cones from around planes - it really does work pretty well -will have to try and edit something and submit it to see if it gets through screening (Tom - don't read this :borat:)
    Senior Member Cary's Avatar
    Re: Photoshop CS5
    I was excited about this when I first saw the video, but don't expect any miracles from it. I tried to use it to remove a simple pink flare cast over a pant leg, and it failed miserably. I eventually just used the techniques in this video: http://www.wonderhowto.com/how-to-remov ... hop-16530/ and ended up with near-perfect results. The sample image used was obviously carefully hand-picked to produce the best possible results (cloudless sky, repetitive grass). Adobe products have 30 day free trials, so you can give it a shot and see if it works for you.
    Re: Photoshop CS5
    Like any other application, you need to understand what its good points and bad points are. I feel it worked great. Everything said it this thread is true. It works but it is not perfect, Like anything else you need to know when to use the application and the software is doing what IT feels it needs to so it will never be spot on 100% of the time. I think it is jaw dropping good.
    I took this and masked
    Filled and got this with NO touchup
    one more
    it is not perfect, if you have a lot of similar areas to work with like sky and grass it is great. lots of applications will not work well, but when it does it is like magic
    From
    to this
    in 8 seconds!
    Re: Photoshop CS5
    :P
