Results 1 to 9 of 9
Thread: Inexpensive Telephoto Lens Question
    Mar 2010
    Des Moines,Iowa
    Are there any decent telephoto lenses available that are under $500.00? I'm looking for one that I could use to take pictures of planes flying at cruising altitude. I'm not looking for Airliner.net or Jetphoto quality,just something that would let me see what the type and airline of a plane is.
    Doug
    Re: Inexpensive Telephoto Lens Question
    Probably not for what you want to do, though if you go film it's fairly easy to pick up a super telephoto for not that much.
    Tamron has an inexpensive 70-300 for about $160 and you can put a 2x multiplier on that and get a 600mm with the 1.6 crop in some digital cameras.... it will be messy, but you should be able ID the aircraft....IF YOUR STEADY!
    I would recommend that Canon 2x multiplier and use the trick on putting tape over some of the leads to use with other manufacturer lenses
    Firstly it would help if you tell us what equipment you're using (Canon, Nikon, Sony, etc.). If you're using Nikon, I would recommend the 70-300mm VR lens (it goes for a little less than $600). Unfortunately, Nikon teleconverters don't work with this lens, but a Kenko converter like a 1.4x does. The other option is save a little more, and you can get a Sigma 150-500mm with OS (there is a Canon version as well as a Nikon version). This lens goes for about $1,000.
    Good lucky!
    Mar 2010
    Des Moines,Iowa
    I'm using a Canon XS Rebel. I do have a Canon 75-300mm lense.
    Doug
    Quote Originally Posted by nssd70
    Doug
    I got a used Sigma 135-400mm f/4.5-5.6 (Canon mount) from Adorama for around $400. No image stabilization and a bit soft once you get above 300mm, but not bad for the price.
    Check the used sections on the B&H and Adorama websites.
    I also got a couple of decent lenses from eBay - a 100-400mm which is also not an IS and worked very well for me for quite a while.
    Senior Member sporky's Avatar
    Mar 2009
    DFW Area
    I picked up the Tokina 80-400 from Adorama for around $550. Decent lens, comparable to the Nikon 80-400 IMO.
    -Tad
