Results 1 to 14 of 14
Thread: JFK 10/11
    Re: JFK 10/11
    Woooooo......Austrian winglets! Good stuff, Eric.
    Re: JFK 10/11
    Niice. I didn't realize Austrian AND Alitalia bring in 76s these days.
    Re: JFK 10/11
    Au with winglets, I like that. did AU switch back to the 767s again?
    Senior Member Cary's Avatar
    Re: JFK 10/11
    A few of mine that weren't covered by Eric's gallery:
    And after everyone else had left...
    Cary
    Re: JFK 10/11
    Oh, that OneWorld is painful to see. That's high on my list. Great shooting guys.
    Re: JFK 10/11
    Great shots guys!!! Those are awesome!! I LOVE the oneWorld!
    Re: JFK 10/11
    Nice shots, guys. I hadn't realized OS had already switched to the 763 again.
    The soccer Jet Blue came in from IAD, I saw it depart.
    Re: JFK 10/11
    Cary, so how's the 7D for planes?
    Re: JFK 10/11
    So far, AF seems good, but I've had all sorts of trouble getting good, consistent results with evaluative/matrix metering. My exposures using it were all over the place, including pretty big differences in metering in the same sequence of shots (I normally shoot 2-5 frames per pass). Also, things seem to generally be underexposed by 1/3 to 2/3. All of this is pretty strange, since the 7D metering is supposed to be more accurate and consistent over its predecessors, yet I never had a problem with the 40D evaluative metering against blue skies. I had so much trouble that I had to switch to manual mode for the rest of the day, after I saw the inconsistencies. Hopefully it's user error, or it's something that can be/is corrected by firmware.
    Re: JFK 10/11
    What settings (mode, exposure compensation, etc.) were you using out there?
    Re: JFK 10/11
    Shutter priority, evaluative metering, no exposure comp. Here are some samples of the exposure differences:
    Top left: 1/800, f7.1
    Top right: 1/800, f9.0
    Bottom left: 1/800, f8.0
    Bottom right: 1/800, f8.0
    Top left: 1/800, f11.0
    Top right: 1/800, f8.0
    Bottom: 1/800, f11.0
    Re: JFK 10/11
    I'm no pro, but I used to have similar difficulties when using shutter priority with several cameras. I started using Av mode at 8.0 instead and got much more consistent shots. Maybe something to consider.
    I still like your shots though.
    Re: JFK 10/11
    Thanks Phil. I might try Aperture priority, however I'd probably rather just shoot in manual since I like being able to set my shutter speed. I've posted my issue to dpreview: http://forums.dpreview.com/forums/readf ... d=33336970 if anyone is interested in the 7D and wants to follow along and see if there is a solution.
