Results 1 to 4 of 4
Thread: KPBI 11/15
    KPBI 11/15
    Not a lot happening, but I did see this interesting KingAir A100 - looks like it has a camera located in the rear underside of the fuselage - surveying aircraft?
    Dec 2007
    Houston Texas
    Re: KPBI 11/15
    [quote="MarkLawrence"]Not a lot happening, but I did see this interesting KingAir A100 - looks like it has a camera located in the rear underside of the fuselage - surveying aircraft?
    INTERESTING CATCH!
    It looks like a a cam or IR sensor gimbal to me.
    Found that it is registered to Dynamic Aviation which sells and outfits a/c for "Intelligence, Surveillance and Reconnaissance, Airborne Data Acquisition"
    http://www.dynamicaviation.com/
    http://www.dynamicaviation.com/brochure_n15l.pdf
    Chris,
    Confederate Air Force Life Member
    Flight Engineer, B-17G Flying Fortress "Texas Raiders"
    http://WWW.AV8PIX.COM, an ICAS member
    Jun 2006
    Westchester NY
    Re: KPBI 11/15
    Where can you go spot at PBI?
    Jordan Greene. - Happy Jetting
    Re: KPBI 11/15
    There is a public park on the south side of the airport just off the perimeter road - right next to Grumman - easy to shoot over the fence. If you need a better explanation - let me know and I'll get directions or a map together.
