Results 1 to 4 of 4
Thread: Canon EF100-400mm F4.4-5.6L IS USM … YESSS!!!
    FLUSHING, NEW YORK
    Greetings,
    Well … the short (and the long) of it is … I visited J&R Photo yesterday … and walked out with a noticeably larger balance on my charge account. [BTW … B&H was asking $80 more … and were out of stock to boot.]
    Later that day I visited LGA Spotter Site B off the GCT … see separate posting in “Spotting Planning and Review” …
    1 - First thing I noticed was the 100-400mm’s size and “whiteness.” I would have preferred a less obvious black finish actually … but that’s a New Yawker speaking I guess. Then there’s its weight … a hefty handful that’ll take a tad adjusting to in terms of carrying / shooting. On this first shoot I found that sitting on a park bench and lifting / shooting only when a plane took off worked well. I left my tripod home … preferring to go hand-held this time to see what the IS could do . I’ll work out a suitable MO as I go along.
    2 - The push-pull zooming was no problem once I adjusted the “Zooming Touch” ring. [My now-backup EF non-L 100-300mm had rotative zooming.]
    3 - I was in AF Focus Mode and had the Focusing Range switch set at 1.8m … would using 6.5m have made a diff here?
    4 - I noticed that the Manual Focusing ring moved from normal handling. I’m assuming this has no effect when in AF mode … yes?
    5 - I had the Image Stabilizer (IS) on but was using Mode 1 … which may have been why some images were less-than-sharp … while others were OK. On second thought … the aircraft may have slipped momentarily out of AF point confirmation mode to cause slight blurring. Yes … I should have used Mode 2 since I was panning the aircraft as they lifted off and banked. Hey … first time out.
    Now … what if I’m a passenger in a moving vehicle … say on the New Jersey Turnpike passing EWR … and want to photograph an aircraft taking off or landing. With both of “us” moving … will IS (in Mode 2) work here?
    6 – BTW … when using any 100mm+ tele lens … IS or not … I increase my ISO from 200 to 400 for greater shutter speed and image stability. Yesterday’s images off the GCT were shot at 1/1000 and f/9.5 … with varying zoom values of course … albeit in IS Mode 1 instead of 2. At that speed and aperture … I’m wondering if IS would have helped at all … even if I was using the Mode 2?
    7 – First use overall comments … the 100-400mm is a dream … with equivalent 160-640mm reach (re the 1.6 digital factor)! And … it’s my first “L” lens … which is a big confidence-booster in itself! I see m-a-n-y images in our collective future as I learn to get the most out of its many features. [Side note - I use the soft carry case (supplied) inside my non-photo carry / shoulder bag. I also don’t leave my gear exposed longer than necessary when in the field … especially now with a big Canon “white lens” on board. Lo-profile (spelled ‘d-i-s-c-r-e-t-e’) Mike is my byword.]
    Everything with the 100-400mm is still new to me … and I’m probably making predictably newbie mistakes and adjustments … so I’d welcome any and all comments / suggestions / tips / and such from you experienced users out there. Thanks.
    Mike (shamrock838)
    how much was the lens?
    May 2006
    Re: Canon EF100-400mm F4.4-5.6L IS USM … YESSS!!!
    Quote Originally Posted by shamrock838
    Changing the focus limiter to the 6.5m setting probably didn't make that big a difference; it really comes into play when the camera is having a bit of trouble focusing. What happens is that the limiter prevents the lens from focusing any closer than that, so it can speed up AF in some tough situations.
    IS, in any mode, is only going to affect movement of the camera, not the subject. To freeze the subject, you need a fast enough shutter speed, and it you're moving too (not just camera shake) you need to make sure you have a very fast shutter. IS also won't help with the changing perspective you get from moving, so a high shutter speed is going to be critical.
    I had rented the 100-400 last month, to have around for the air shows (McGuire and Jones Beach) and I loved it. I had some issues with the zoom, but after a query on another site it seems to have been a problem specific to that copy. I'd love to get one of my own, but I just need to get myself into "saving money" mode to do it!
    (P.S. There's been some speculation, but nothing particularly credible at this point, that Canon is considering a Mk II version of the lens, with a "normal" rotating zoom and constant f/4 aperature. I don't put too much stock into that, but that doesn't mean I'm not hoping for one to flood the used market with cheap f/4.5-5.6s!)
    FLUSHING, NEW YORK
    Canon 100-400mm
    Quote Originally Posted by AirtrafficController
    AirtrafficCintroller,
    J&R has the lens going for $1310 while B&H is asking about $1390.
    Mike (shamrock838)
