Thread: Aircraft Landing and Takeoff Speeds
    FLUSHING, NEW YORK
    Greetings,
    This question came to mind recently when spotting aircraft arrivals to LGA runway 4 from Plane View Park.
    Does the FAA regulate landing ... and takeoff ... speeds or are they dictated by the aerodynamics of the aircraft themselves?
    Those arrivals at LGA 4 seemed to be pretty uniform to my untrained eye. Thanks.
    Mike (shamrock838)
    DTW
    Well, normally ATC will either advise a speed due to traffic, or you will use the standard landing speeds of the aircraft.
    nwa FOREVER!
    FLUSHING, NEW YORK
    LANDING SPEEDS OF AIRCRAFT
    Quote Originally Posted by nwafan20
    Are you saying that each aircraft type can a different landing speed?
    What might some of these be ... so I have some idea in this matter? Thanks.
    Mike (shamrock838)
    Ultimately it is strict dictation based on aerodynamic capibilities but ATC in certain cases can issue requests like maintail 170 till .5 DME than normal approach speeds. It is ultimately though it is what the airplane can do based on location etc. I have more than once flown a C172 into MIA and kept her right up at redline untill over the numbers for the heavy jet traffic behind me when I was playing around with time building down in Florida.
    DTW
    Re: LANDING SPEEDS OF AIRCRAFT
    Quote Originally Posted by shamrock838
    Mike (shamrock838)
    Well, yeah they have different speeds. You can't expect a Cessna 152 to go the same approach speed as a 747.
    As for the exact speed, I'm not really the one to ask, sorry.
    nwa FOREVER!
    Apr 2006
    ATC can only give a particular speed to the Outer Marker. After that it is pilots discretion, which they usually just have their VREF speeds which is decided by the aircraft or pilot.
    Northeast
    Quote Originally Posted by PHL Approach
    Or if no outermarker exists, outside the final approach fix or 5 DME from the runway (whichever is closer). IOW: ATC cannot technically issue a speed restriction inside the FAF or OM, because approach speeds (Vref) are determined by various aerodynamic factors and should be slowed to around the OM/5 DME to maintain a stabilized approach.
    Jason
    CFI/CFII
    Part 135 Dispatch
    Re: Aircraft Landing and Takeoff Speeds
    Greetings,
    Mike (shamrock838)
    the speeds at which an airplane will rotate, take off and land are determined by a, the airplane's weight and engine performance and b, the atmospheric conditions (ie. air temp and press.) the fact that LGA arrivals look to be uniform is that most jets have very similiar approach speeds. the props will be slower, but there will be greater spacing between them and following a/c to allow for that.
