Results 1 to 15 of 15
Thread: Pan Am could have ponied up for a Concorde
    Geez, Tommy, PanAm could have at least ponied up the cash for an SST. That Makeshift SST is a joke! :D
    Mario that is PanAm with the pointy nose not TWA.. Do we need a good eye doctor?
    Pan AM, TWA, Tower, I keep mixing up my fallen carriers.
    I see we changed our post, LOL btw I'm not a PanAm fan Mario, LOL shall I call you a tool or do you want to take the honor, LOLOLOL ;)
    Jun 2006
    For those of us who don't parlez francais, what does it actually say? Was this for some sort of research?
    I'd help out if I could but the print is splotchy
    Err, why did the photo change?
    I have a feeling our good friend Mario has been drinking a bit to much wine today.... First he called PanAM, TWA. then he thought I was PanAM fan and now the TWA terminal is pictured. Put the wine glass down Mario and step away from the cork.
    hicccup...
    burp.
    huh?
    If you use NYCA hosting and upload a file with the smae name as something already in it, it will overwirte the old one. So perhaps Mario (or someone) uploaded a photo with the same name and it overwrote the previous one.
    Can anyone share with us what the previous image was of? This is one of hte most confusing threads I've seen here. haha
    Hey, I guess as I was realizing this and correcting it and you were you drawing the same conclusion at the same time!
    -mjc
    Now I get it! Very funny. :)
    La flotte complete des Boeing 747 utilises pour les essais. Fin aout, les cinq appareils comptaient au total quelque 500 heures de vol. La sonde en aluminium de 9,7m long qui equipe l'un d'entre eux sert a l'erude des charges aerodynamiques dues aux rafales.
    The complete fleet of Boeing 747s used for trials. At the end of August, the 5 airplanes (lit: machines), had amassed a total of some 500 flight hours. The aluminum probe of 9.7m length [32 ft.] is equipped with a set to learn the aerodynamic forces due to the gusts.
    Jun 2006
    Merci beaucoup Mateo, at least now I know it wasn't a party hat
    Senior Member Futterman's Avatar
    Rego Park/Forest Hills, NY
    Hey, Mario, how many fingers?
    Quote Originally Posted by Mateo
    This may not be true for this particular probe, but most of these "needle noses" on experimental aircraft are - among other things - just extended pitot tubes.
    It makes sense that we'd see this feature on completely new aircraft models and designs, too, since it helps to determine and assign an accurate airspeed to a certain V-speed (say, stall speed). Placing the pitot that far away from the fuselage eliminates "position error" caused by phenomenon like the boundary layer, and it also allows the instrument to be properly calibrated and used.
    Now it's time to put the Urcle glasses away and hit the sack. :)
    Brian
