Results 1 to 15 of 19
Thread: Crazy JFK Plan For The Future
    riiiiiiiiiiiiiiight....
    I think that's a bit much.
    Their rial idea to link all three airports is interesting, except for the fact that for people in Manhattan trrying to get to JFK, the one that serves the most passengers, they have to go through LGA or EWR first.
    They apparently just winged this without actually looking at how airports operate.
    DTW
    That would never work, especially the runway setup, you can't have 2 operating runways so close to each other, the approach paths would be the same and therefore you couldn't use them at the same time.
    Like Gotham said, they have no idea how an airport operates...
    nwa FOREVER!
    I had to examine that figure twice in an effort to try and figure out what they want.
    Seems like a solar blanket to be suspended above the entire airport, of course, with the exception of covering the runways?
    Not sure what the goal is. Seems like an obvious first cut rendition. As for the doubling of the runways, I like it but don't see it happening.
    Lastly, considering the "take the train to the plane," now known as "JFKairTrain" took 25 years to come to fruition, I doubt such an expansive task would be completed anytime soon :)
    Very intertesting idea but very far fetched. Remote screening spread out all over the place leaves huge holes in the system and increases the risk of a breach. Also did they think what to do while the construction takes place? This kind of project would require JFK to basically shut down.
    Member AndrewM's Avatar
    Oct 2005
    Los Angeles
    uhhh.....while I appreciate their desire to think outside the box, and not every idea they have is bad, it seems like it was thought out by someone with no idea of how an airport operates. On page two where they show JFK in a before and after representation there are little plane silhouettes traveling in different directions on parallel runways. Maybe one is taxiing but I doubt it. If they didn't even know how a basic traffic pattern operates how are they figuring out the intricacies of design? Oh well, nice try I guess...
    Quote Originally Posted by nwafan20
    ...you can't have 2 operating runways so close to each other, the approach paths would be the same and therefore you couldn't use them at the same time.
    Not necessarily. With two very close parallel runways built with minimum distnaces (150 feet apart, right?), you can have one plane on one waiting to depart while the other lands on the nearby one. Time is aved by not having to wait for the plane to clear the runway for the next plane to start it's roll or to even turn onto the runway.
    LAS's runways are right next to each other. One is used for departure and one arrivals. Works very well for them.
    Senior Member Ari707's Avatar
    Oct 2005
    West Hempstead, NY
    4. The end of fast-food ripoffs at the gate.
    Flight pushed back? Status boards at each shuttle hub let you wait out the delay at local restaurants and coffee shops, instead of their overpriced airport equivalents.
    And where wouldthese be? the hotdog truck by the shelter on rockaway tpk????
    More hilarity...this is actually a three page article.
    Map of their plan for a massive loop shuttle connecting all three airport, complete with a jetBlue 777 and an unmarked passenger 741 at the gate! http://nymag.com/news/features/27826/index2.html
    Intro, with illustration of "airport" entrance at Union Square: http://nymag.com/news/features/27826/index.html
    As far as the remote checkpoints go, I guess they never noticed the millions of dollars in ticket counter equipment and space collecting dust at the Jamaica AirTrain terminal. All these ideas have been thrown about before either officially or by hobbyists, and deemed impractical or too expensive. Similar quality maps have been drawn on internet message boards by non-professionals.
    This is all well & good, albeit a bit far-fetched, but aside from the security holes, the roundabout way to get to JFK, etc...where is the estimated COST of this project. Considering the parallel runways, what are the planning to destoy? Cargo Road (Hangar 3,4,5, DHL, FedEx, USPS & US Customs?) They can't build inside the the runways as the JetBlue & BA Terminal's would then be too close to the active with no taxiway to get to them. Same on the otherside with the Delta terminals, and unless they plan on filling in Jamaica Bay....
    DTW
    LAX's runways, by my estimation are a good 600 or so feet apart, the runways in that diagram can't be any further than 200 feet apart on the first set.
    nwa FOREVER!
    I would estimate the total cost at about $250 billion. Until Exxon finds an oil reserve under Central Park, these guys should pitch their services to the overly rich nutjobs in Dubai.
