Results 1 to 4 of 4
Thread: my first uploads hopefully here for a net
    here are my first real quality shots with a 10D that I took yesterday let me know what you think........
    Nice pics, but these are too small. Did you upload bigger versions? Anet's min is 1024
    Not bad Ryan, I'd watch your espouse compensation a bit. They are a bit over espoused.
    Nice shots - the Singapore, and to a lesser extent the JAL, look overexposed. The Singapore is especially noticeable around the forward fuselage. You might try underexposing a bit when shooting. Check your histogram to ensure you aren't blowing out the highlights - that's easy to do with a white fuselage, I have lots of JetBlue shots where that is an issue.
    The Evergreen could stand a little more contrast, that will help the colors pop. I think that would also help the colors on Singapore, but will only make your overexposed areas worse.
    And as Nick said, check the size you are saving at, should be at least 1024 pixels wide.
