Results 1 to 4 of 4
Thread: MD-80 Crash Video
    Senior Member Ari707's Avatar
    Oct 2005
    West Hempstead, NY
    MD-80 Crash Video
    Re: MD-80 Crash Video
    Quote Originally Posted by Ari707
    http://video.google.com/videoplay?docid=-6838776830077767976&pl=true
    Now that's a hard landing!!!
    This was not a failure of the aircraft, this was to test the maximum impact
    to make sure that there would not be any structural problems with the
    aircraft. The Pilot and Co-Pilot did one or two landings successfully and
    then in this video, they let the sink rate get way to excessive. This was
    the prototype MD-80 and was later used in commercial service and I
    believe it was also used as the unducted fan tests at the end of her life. I
    am not 100% sure about this being the same aircraft used as the unduced
    fan test, but cool none the less. I would have loved to walk around the
    aircraft after all the metal cooled down!
    I was actually impressed at how the main gear held up. The nose gear seems to have collapsted and the structure forward of the tail also seems to have done well with little visible shock.
    I was impressed with the main gear too!
    The nose gear looks intact but it looks more like he blew the tires and was shooting sparks from the rims....if you look close, the sparks end at the end of the footage...... Tire probably started to spin at that point.
    (The unusual low down nose seems to be camera angle, the engines would be really pointing at the ground if the nose collapsed.)
    The spot just behind the wings and mains was beefed up for the MD-80 because the desingers knew this was to be the most likley place for a break. In the old DC-9's, this was the first place that would fail shown in the picture of an old Eastern DC-9 here. Look like the designers over designed it for the MD-80.
    DC-9 Weak point
    http://www.airliners.net/open.file/0077849/L/
