Results 1 to 11 of 11
Thread: what's heavy
    Senior Member Tower Air's Avatar
    rsw
    what's heavy
    when u hear atc say heavy after the planes call sign what do they mean?
    "Regardless of where you go or what you do with the rest of your life,
    you can always know that when fate chose
    you for the ultimate test, you were not found wanting".
    Captain William Kinkead in a letter to the crew of TWA Flight 843
    Re: what's heavy
    Quote Originally Posted by Tower Air
    Aircraft taking off behind it need to wait for the wake to pass....Longer time needed for Heavy aircraft or aircraft with large wake due to wing design
    747,Dc-10, MD-11, A340, A330, A300, L-1011 and.......757 wing is horrible with the wingtip wake vortices's so that is also on the list.
    the takeoff weight of the aircraft is over 250,000 lb. in addition, the wake turbulence behind some airplanes (757 namely) that they are just assigned a 'heavy designation."
    there are more rules to wake turblence, send me a PM if you want more clarification.
    Senior Member K9DEP's Avatar
    Aug 2005
    FRG-TWR
    yeah, basically 200,000/+lbs but usually also the controller will add 'caution wake turbulence from the NWA 747 . . . .'
    Jetblue Pilot departure announcement : "We are pleased to have some of the best flight attendants in the industry ...Unfortunately none of them are on this flight...!"
    A 757 is not referred to as heavy on the radio,* but for wake turbulence separation standards, it's treated as a heavy. And, yes, controllers will say something like 'caution wake turbulence, you're 6 in trail of a 757,' when they otherwise wouldn't say that you're 6 in trail of, say, an A320. Heavy goes on any aircraft with an MTOW over 250,000lbs.
    *ATA's 752s are certified with an MTOW of 255k, and, thus, are heavies.
    Brisvegas - BNE/YBBN
    This topic was discussed on some of the Aussie forums I am a member of, they might be of interest 8)
    http://jetspotter.com/phpBB2/viewtop...ighlight=heavy
    http://www.vpmag.com/yssy/viewtopic....asc&highlight=
    Not just he 757, because airlines like BA use RB211's on their 767's and 747's!
    Senior Member SengaB's Avatar
    At MDW The word "Heavy" is frequently used on all 757-200 aircraft at that airport (ATA). I have always heard a 757-300 refered to as "Heavy" no matter where what airport you are at.
    Also you might catch a Mexicana 757-200 pilot slip and use it at an airport.
    Senga
    Senior Member Ari707's Avatar
    Oct 2005
    West Hempstead, NY
    a 757-300 is over the weight limit and therefore is "heavy"
    DCA
    BMI at IAD and Icelandair at BWI use(d) "Heavy" with their callsign.
    Both were 757s.
    Rafal
    "Its basic economics, I don't understand it at all..." - Randy Marsh, South Park, CO
    Rockaway Beach, NY
    When it takes a 12 pack to make her look 'good' that is considered a HEAVY ;)
