My latest A.net go around.....![]()
http://jetphotos.net/viewphoto.php?id=7390208&nseq=0
And ofcorse it was screeners choice and Top of the day on JP.
I agree with the grain (easily fixable with NR software), but color cast? That's A.net for you. They won't take any color casts like that, even if it looked like that in reality, unless you're a screener. Your golden fuselage (which I'm guessing is the cast they're referring to):
is virtually identical to that on Stefan's pictures:
Not dumping on Stefan's pics, BTW...they're great, and I was pointed to them by a colleague who was there and told me that's how the scene looked. Just making the point that non-screeners are unlikely to get the same benefit of doubt on early/late day color casts.
I dont know why This was rejected can someone explain me these two photos on why they were rejected?![]()
See my post re: the above pics on the pre-screening thread :-(
Lucas, this page should give you some guidance:
http://www.airliners.net/faq/rejection_reasons.php
There's multiple issues with those photos, and they should be stated in the e-mail you received from A.net.
Lucas, this is directed at your question re: your rejections ... just in case you may think it is regarding some other post.
--Both pictures lack punch or what is commonly known as A.net contrast. A lot of what Airliners looks for is uniquely their own taste, do not think it is about what everyone agrees with. So keep it in mind that just because you or one hundred others disagree, it is somehow wrong or right. It has nothing to do with wrong or right, it only has to do with what A.net likes to see.
Top Pic (A320)
-Lack of contrast
-Motive: This is related to your motive for the image. Meaning what did you intend to show? For Airliners, the intent or motive should be primarily the airplane. They like it to be centered and balanced. So, your image lacks a motive. There is too much space on the left of the aircraft and it is also not centered horizontally. The airplane is also not centered vertically. Finally, it is not level. The image needs a bit of CCW rotation. That is Counter-Clock-Wise ...
-Soft: It lacks sharpness. Images posted to the A.net database must be A.net sharp. This is a level of sharpness you and many may not be very comfortable with as it borders on oversharpening. Be prepared to suffer in this area. I still get soft rejections from time to time. I have learned to accept them and recognize them :-)
Bottom Pic (B737)
-Soft
-Level
-Motive
In this one, the left horizontal stabilizer is stabbing the edge of the image frame. This is not acceptable and it is also unbalanced as there is too much space to the left of the aircraft.
I will upload a couple of edits to see if I can highlight some changes you can make and try to upload again.
blurry/JPG Compression Artefects
http://www.jetphotos.net/viewreject_b.php?id=3896850
Dust Spot/Dirty Scan
http://www.jetphotos.net/viewreject_b.php?id=3896853
Too much or too little contrast
http://www.jetphotos.net/viewreject_b.php?id=3896856
Dark/underexposed/soft
http://www.jetphotos.net/viewreject_b.php?id=3896857
Blurry
http://www.jetphotos.net/viewreject_b.php?id=3896862
Blurry
http://www.jetphotos.net/viewreject_b.php?id=3896864
Blurry
http://www.jetphotos.net/viewreject_b.php?id=3896868
Blurry/soft
http://www.jetphotos.net/viewreject_b.php?id=3896869
