Page 85 of 92 FirstFirst ... 3575818283848586878889 ... LastLast
Results 1,261 to 1,275 of 1369
  1. #1261
    Senior Member JDANDO's Avatar
    Oct 2009
    KMSP, KANE
    Quote Originally Posted by wunaladreamin View Post
    Is there a spikes on the extreme edges of the histogram? That's what gives the shot a harsh look. Also when you correct levels, are you doing it in RGB? Or are you doing it by individual color channel?
    See if this helps... While there are sharp spikes, they are not up against the right hand side and also not too high up on the scale. Also, notice how the middle of the histogram got fatter? That means more data is now visible in that range of grays (yes, they are all grays per layer of color )
    Everything I learned about histograms and color correction after much reading on the subject, was from the great Dan Margulis. I suggest you read him and learn a lot about how digital data is stored and used to represent real world scenes. Absolutely great learning from any of his books. The ...Canyon Conundrum... being my favorite!
    His recent Picture Postcard Workflow is a terrific video tutorial from what I hear (have not had the pleasure...)
    http://www.danmargulis.it/index.html
    Thanks for the help guys. This was a horrible light day, but AF1 was in town and I figured I would give it a go.
    Levels correction is done in RGB.
    Jeremy in Minnesota
    My pictures on jp.net
  2. #1262
    Even though its quicker to do it in RGB, you'll have more accurate correction using individual channels.
  3. #1263
    Nov 2012
    Grand Rapids, MI
    These rejections I'm going to have to call BS on!
    http://www.jetphotos.net/viewreject_b.php?id=4154787
    Both rejected for overexposure and CMOS dust spots. The overexposure I can see, but given the time of day and the amount of snow on the ground pictures are just going to look a bit brighter. The dust spots are totally messed up by the screener. The "dust spots" he/she saw are water vapor coming from a building nearby, anyone can clearly see. When equalized, NO dust spots are seen anywhere! I'm going to appeal, because whoever screened this clearly DID NOT take his/her time actually looking at the photo.
  4. #1264
    Alex, sorry, no BS and you only linked one image twice... what is the URL for the other one?
    In any case, the one above is clearly NOT overexposed; the brightest white I can find is about 251 level out of 255. Bright but not over in my opinion...
    But it does indeed have large dust spots!!
    Equalized I can see them clearly, but some curve work can show them even more
  5. #1265
    Nov 2012
    Grand Rapids, MI
    Oh wow, when I equalized none of that seemed to show. Weird. The other must be the same.
  6. #1266
    Why do you find it weird? If you;re not equalizing your FINAL JPG that you saved for upload, you're not really seeing what THEY see... always keep that in mind. I usually save the file and then open it back up in PSCS6 and EQ and Curves to see if there is anything I missed. Now for some of the rules applied by the two main database sites as I know them:
    JP.net
    --ANY dust spot or blemish will be revealed via EQUALIZATION even if invisible in regular shot and will be rejected (usually) and they are VERY good at this ;-)
    A.net
    --Screeners MUST be able to see the spots and/or blemishes UN-EQUALIZED ... Equalization is at the discretion of the screeners to CONFIRM something noticed in the regularly screened image as seen by anyone as normally displayed. So if there is a spot in the image but it is not discernible to the naked eye, it gets a pass usually.
    Another trick to use (one used by the screeners at A.net is to rapidly circle your eyes around a picture. Your eyes are so good at hiding the HOLE in the back of the retina (where the optical nerve is) that you miss stuff that's directly focused / projected on that spot. By moving your eyes around quickly you pick up subtle differences in the image such as spots quite easily.
  7. #1267
    Nov 2012
    Grand Rapids, MI
    I am equalizing the final JPEG, it is just hard for me to see dust spots for some reason. I guess I'll just have to train my eyes to see them better. It also doesn't help that my computer's screen is below average.
  8. #1268
    Also good to know is that screeners use either a 24inch S-IPS panel or larger at at least 96dpi and hardware calibrated. If you are not doing the same, you're just guessing and getting lucky ... seriously, the A.net database literally wants perfect shots or close to it. There is no point in thinking of it any other way... you can upload to literally any other database or on-line gallery... they may not be as strict... but A.net is aiming to have the highest standards and that's their turf, whether you agree with it or not ;-)
  9. #1269
    Nov 2012
    Grand Rapids, MI
  10. #1270
    You're in a double edge sword world there - the top of the aircraft is very bright - which can be classed as over exposed. While the Air Canada red titles are good - the express and the reg seem soft - just comments from looking on my Mac - if you can selective sharpen the tail area before processing - I think you might be in a better place...
  11. #1271
    Nov 2012
    Grand Rapids, MI
    Thanks Mark! I can see soft, but overexposed I dont think so, given that the sun was high in the sky, few if any clouds, and tons of snow, so photos will be a bit brighter, right?
  12. #1272
    Senior Member RomNYC's Avatar
    Jan 2011
    Away from home
    It does look overexposed to me as well, mainly the fuselage. I would play with the brightness a bit. As for snow, sun, etc. the screeners don't know that and I believe they screen regardless of the conditions. First impression is important, and my first impression was "whoa, bright!". Should be easy to fix, try again because this is a very sweet shot.
  13. #1273
    Oct 2009
    KMSP, KANE
    Overexposed in Minnesota :)
    Reprocess, dial back the exposure a hair, sharpen a bit and it is in.
    Jeremy in Minnesota
  14. #1274
    Quote Originally Posted by deltaA330 View Post
    I've said it numerous times in this thread already...LEARN YOUR HISTOGRAM! It will not only end your exposure issues but it will help with the overall sharpness of the image as well.
  15. #1275
    WAAAAY overexposed, Alex... I actually SHOWED you how to get it better and you ignored good advice? Shame on me...!
