Page 77 of 92 FirstFirst ... 276773747576777879808187 ... LastLast
Results 1,141 to 1,155 of 1369
  1. #1141
    Quote Originally Posted by Chris102 View Post
    Any thoughts on this one? Rejected for "dark."
    http://www.airliners.net/addphotos/r...avp_4987_2.jpg
    Oooh, yeah Chris. Looks very dark to me sorry. Here is what I think would be better to my taste anyway. Although harsh light to begin with... :-)
  2. #1142
    Pennsylvania
    Thanks Manny! I'll brighten it up.
  3. #1143
    Pennsylvania
    Just got a few rejections and thought I'd post them here to see if I have any chance at appealing.
    Low contrast:
    http://www.airliners.net/addphotos/r...69img_4791.jpg
    Overexposed, soft: (someone else has a near-identical photo in the database of this aircraft, but that wasn't rejected for o/e):
    http://www.airliners.net/addphotos/r...96img_4847.jpg
    Contrast high, "nose soft contrast," "soft soft contrast:" (too much contrast? I guess they punish you for using a professional camera/lens):
    http://www.airliners.net/addphotos/r...48img_4711.jpg
    Soft (I don't really see it being soft--maybe someone here can point it out):
    http://www.airliners.net/addphotos/r...45img_4780.jpg
    Thanks as always!
  4. #1144
    I think they are all fixable. Remember that Airliner's sharp may not be your idea of sharp. It is a very very fine line between overdone and just a tad soft for their standards. So, yes, I tend to agree on all the above counts. I think they are all fixable. Just do exactly as they ask and you should be in on round two.
    For the sharpening, on those that are soft, just another round of USM on the plane, or Smart Sharpen at very low amount and radius (say 30 at 0.3) will give you a crisper look. Pro cameras are EXACTLY the problem you;re having. Trust me, I get rejected A LOT!!!!! lol. Pro Cameras demand a higher level of attention as the files come out a bit more RAW.
    Do you shoot RAW or JPGs? If you're processing from RAW, you will have much more trouble than from JPGs until you get the right mix of settings for A.net and JP.net output.
    Once again, A.net sharp is NOT by any means your preferred sharpness. This is not a big deal but more a preference. However, one thing you must keep in mind is that certain parts of certain aircraft at certain angles and certain weather will render them LOOKING less contrasty or more and thereby enhancing or hampering apparent sharpness.
    For example, the windows on the last one could you a bit more USM ... they look soft partly because of lack of contrast due to the WX conditions... etc. etc.
    I also tend to sharpen wheels and windows a lot more than the rest of the plane and usually completely erase sharpened airframe edges or boundaries. I will also oversharpen very very small or low contrast edges.
    The fact that another image is in the DB seemingly identical to yours will matter not much unfortunately. You are screened on your own merits alone, and only point out another accepted photo if there is a mistake of some kind other than editing
  5. #1145
    Pennsylvania
    Thanks, Manny! I just got a chance to rework these tonight.
    I've been getting a lot of rejections lately, too. All of mine are either for soft or contrast. Eventually I'll get the hang of the A.net required processing!
    I shoot RAW. The worst part is having to edit them--they freeze up my computer and it takes forever just to edit a few!
  6. #1146
    Senior Member NickPeterman's Avatar
    Nov 2011
    Richmond, VA/Roanoke, TX
    Well, I decided to complain about a recent rejection finally, so we'll see how it goes...
    http://www.airliners.net/aviation-fo...d.main/367153/
  7. #1147
    Personally, I think you have a good reason to appeal Nick - both look very acceptable.
  8. #1148
    Senior Member Kris V's Avatar
    Jan 2012
    Anchorage, Alaska/ Fairbanks,Alaska
    Thanks Anet...
    Is this a good fix?
  9. #1149
    Senior Member JDANDO's Avatar
    Oct 2009
    KMSP, KANE
    Quote Originally Posted by Kris V View Post
    Thanks Anet...
    Is this a good fix?
    Looks better to me if it was a "dark" reject. Personally I like the first edit.
    Got lit up on jp.net for this;
    overexposed
    Jeremy in Minnesota
    My pictures on jp.net
  10. #1150
    Oct 2009
    KMSP, KANE
    Rough week on jp.net....
    Bad info in aircraft???
    http://www.jetphotos.net//viewreject_b.php?id=3962809
    Zooming in on the plane it appears to say TBM850 above the wing, but the FAA website and Airport Data have as a 700. Perhaps I should not have believed the government.
    Bad info in serial number?
    http://www.jetphotos.net//viewreject_b.php?id=3962819
    Perhaps a space at the front on the s/n?
    Wrong categories?
    http://www.jetphotos.net//viewreject_b.php?id=3962821
    Appreciate some help on these.
    Jeremy in Minnesota
  11. #1151
    Jeremy,
    The whites on the fuselage are showing close or at 255 on my setup here at home... I would back out the contrast a bit and it should be ok.
    The Socata is clearly a TBM700 from not just the Govt site
    N1HS: Seems like you entered the serial with the regi... Serial goes into its own field :-)
  12. #1152
    Oct 2009
    KMSP, KANE
    Thanks Manny!
    Not too surprised with the reject here, shooting from the Parkade and nothing is squared up. Horizons are my nemesis.
    http://www.jetphotos.net/viewreject_b.php?id=3966053
    Any suggestions on which way it should rotate?
    Jeremy in Minnesota
  13. #1153
  14. #1154
    Oct 2009
    KMSP, KANE
    Thanks Doug, it is back in the queue with a tweak.
    Jeremy in Minnesota
  15. #1155
    Pennsylvania
    Anyone think I have an appeal here? It was rejected for being "washed out," but I don't think it's overexposed...
    http://www.airliners.net/addphotos/r...2_mpo_4695.jpg
