Page 75 of 92 FirstFirst ... 256571727374757677787985 ... LastLast
Results 1,111 to 1,125 of 1369
  1. #1111
    Halos around aircraft... I think the fact that it was very humid that morning, there was a bit of turbulence and when the plane goes through it... what can you do. To see it you must view it under Photoshop and Equalize the histogram or compress it in curves...
    JetPhotos.net VX San Francisco Giants Beard and Mustache
  2. #1112
    Pennsylvania
    Any thoughts on how to level this one? I always have problems uploading shots from this spot--it always takes forever to get them "level" according to A.net.
    By my Photoshop ruler, it is level with the horizon. Thoughts?
  3. #1113
    Senior Member Cary's Avatar
    Quote Originally Posted by Chris102 View Post
    If Level was the only rejection reason, I'd appeal it...looks perfectly fine to me. Is it just me, or does the striping down the airplane look fuchsia/red, instead of gold, though?
  4. #1114
    Senior Member JDANDO's Avatar
    Oct 2009
    KMSP, KANE
    Quote Originally Posted by Cary View Post
    Colors look a bit off to me, but I am no expert
    Jeremy in Minnesota
    My pictures on jp.net
  5. #1115
    Quote Originally Posted by JDANDO View Post
    After looking at it again, I think it's just the picture being so small that the gold stripe is mixing with the black stripe outline to make it look like a different color.
  6. #1116
    Cary, I think that stripe is very reflective strip so since it is at an angle to the floor, it looks like it may be reflecting dark instead of the bright sky.
    Jeremy, color looks fine to me given that it looks very overcast and early.
  7. #1117
    Dec 2011
    Florida
    yea,it looks fine to me Mabye the less open space? mine was only rejected For centering And left a lot of open space >.<,there really strict
  8. #1118
    Dec 2011
    Florida
    Nice how did that get rejected? Colors or cenerd?
  9. #1119
    Quote Originally Posted by Just_Lucas View Post
    Slight blue cast on the window shades..
  10. #1120
    Cary, do NOT disrespect me, those shades are YELLOW!!! You blind? You always confuse blue with yellow...
    Lucas, it was properly rejected for halos ... I pushed the Highlight recovery slider in Lightroom a bit too hard to the left and while I argued that in normal viewing conditions it does not show much, under Histogram Equalization, it does show some areas with halos. JP.net rules state that the slightest issue with the image under severe scrutiny should be rejected. So it is been re-edited properly and re-uploaded.
    Yellow shades, Cary, YeLlOw!!!!! And the beard is a deep charcoal, not black... the white, you know it, nice and yElLoW
  11. #1121
    ROFL, Manny
  12. #1122
    Pennsylvania
    Thanks for the help on the C-32, Cary. I'll be appealing it. The stripe doesn't look red in the larger image. I noticed the smaller images of the C-32 on A.net all have this same color thing going on.
    Any thoughts on this one? It was rejected for needing a CCW adjustment, but it is already leveled by that orange/yellow line under the aircraft on the ground at the end of the pavement.
  13. #1123
    It may be level based on the line, Chris, but looking at it on my monitor, it does look like it needs some CCW - it just "feels" like it is going downhill.
  14. #1124
  15. #1125
    Hey Chris, use the runway or whatever that is behind the aircraft Here is a quick edit using the guides Photoshop to help ... I used the measuring tape to lay down a line on that feature to help with accurate rotation.
