2011-01-04, 10:42 PM
#766
Jeremy,
From what I see in your image (the large version you linked) the cockpit area looks to have serious CA. Here is a set of 100% crops:
Cockpit is easily seen... the right of the cockpit, take a look at the tug. The driver's leg shows it, the wheel also shows blue/red shift which is typically CA. On the oher hand, the cockpit windows are likely showing lens flaring... or registration errors... meaning some of the color channels were not properly rendered by the CCD/CMOS as the lens did not bring it to the proper focus (it is hard for me to explain this stuff... others are better at it :-) like Wikipedia or Cambridge in Colour)
Look at the left side, the areas I highlighted show CA (red/purple/blue shifting)
You may have to ZOOM IN to about 500% to make it more obvious.
As far as sharpening, you may be killing yourself with the 100,0.2,0 setting as NO TWO IMAGES require the same sharpening setting. I usually will end up with 5 layers and each with different sharpen setting if needed and then mask the rest. Some areas with super fine detail benefit from super small USM settings while others can benefit more from higher settings.
50,0.5,0 will work VERY WELL on larger areas of contrast with a single pass. Depending on how much small/medium/large detail there is, you should use lower/higher as needed.
The best way in my opinion, but it is more time consuming and even more obnscure to some :-) is using a find edges process and sharpening that. This has a way to AUTOMAGICALLY finding areas that need more and areas that need less sharpening in a dynamic way dictated by the image itself.
2011-01-04, 10:50 PM
#767
2011-01-05, 12:38 AM
#768
I honestly don't understand what the heck JPG Artifacts is.
2011-01-05, 02:18 AM
#769
Well, I totally know and understand what it is, so that's why I am puzzled I got rejected on these for that reason. I don't see artifacts even at high magnification. The Evergreen I can see a bit of it at 500% magnification. Here is a good writeup
http://en.wikipedia.org/wiki/Compression_artifact
2011-01-05, 08:58 PM
#770
Brandon, congrats :-) JP.net liked it
[jetphotos]7015908[/jetphotos]
2011-01-06, 06:27 AM
#771
Yep! Was about to post that lol
2011-01-06, 08:53 AM
#772
Sorry for stealing your thunder. When I saw it I immediately recognized it LOL
2011-01-07, 06:51 AM
#773
2011-01-07, 07:15 PM
#774
this one had multiple issues :(
http://www.jetphotos.net/viewreject_b.php?id=3273158
Any clue on how I hosed up categories and location.
2011-01-14, 11:30 PM
#775
2011-01-15, 06:26 AM
#776
I would agree, not centered would have been more appropriate in my opinion though for that rejection.
2011-01-15, 12:55 PM
#777
That's size ratio. For JP it has to either be 3:2 or 4:3.
2011-01-15, 01:42 PM
#778
2011-01-18, 02:13 PM
#779
2011-01-18, 04:10 PM
#780
- You may not post replies
- You may not edit your posts
Forum Rules
