Page 46 of 92 FirstFirst ... 3642434445464748495056 ... LastLast
Results 676 to 690 of 1369
  1. #676
    May 2006
    Re: Post Your Recent REJECTIONS!
    Would appreciate some help on this.
    http://www.jetphotos.net/viewreject_b.php?id=2942938
    This is the second time this photo has been rejected and I am not sure which way to rotate it. I originally did it 5 degrees CCW.
    Thanks!
  2. #677
    Might be wrong Isaac - but - did you try the line on the top of the hangar door to the right of the Hawk??
  3. #678
    Jul 2006
    Albany, NY
    Quote Originally Posted by Greg_NY
    Thanks!
    Probably the verticals on the light poles that got you the rejection. They all appear to be leaning to the right.
    Do you use photoshop? It's an easy fix.
  4. #679
    May 2006
    Thanks for the suggestions. I will try again.
    In the first submission, I did line up the light poles to be vertical, but that got rejected.
    Thanks
  5. #680
    That's a tough photo, Isaac - the light poles look like they lean to the right, but the hangar doors on the right side look like they lean to the left.
  6. #681
    Why not post it in the pre-screening and I'm sure someone will be able to tell if it's right!
  7. #682
    May 2006
    Maybe I'll take the average of the two... :lol:
  8. #683
    Jul 2006
    Albany, NY
    Thanks
    'shop out the light poles (oops, I didn't say that)
  9. #684
    Thing is, these got rejected for quality and compression, but that's only because they made me resize them, so when you blow them back up, of course they look jaggy:
    http://www.airliners.net/procphotos/rej ... fdash8.jpg
    http://www.airliners.net/procphotos/rej ... faa767.jpg
    I don't understand anet. They even said one of them was too grainy, but both were shot at ISO 100. Am I doing something wrong when resizing them? They don't want anything bigger than 1200 pixels, but that's significantly smaller than some of the 'medium' size photos in the database.
    Any help or tips are appreciated, kind people. Thank you
  10. #685
    Mar 2010
    Well the second one seems too dark, But the size limit with A.Net is 1600 but the picture needs to be suberb quality to be accepted at that size.
    Best tip is do all of your coloring at the full size. Crop it, resize and then sharpen. Always do the sharpening very last. Hope that helps
  11. #686
    I'm missing something or my laptop screen isn't showing me - where?
    http://www.jetphotos.net/viewreject_b.php?id=2972974
  12. #687
    Mark-
    At first glance it seems like the nose is a bit soft...particularly in the nose gear. The paint may throw off the blur alarm with the way it shines that it could be interpreted as soft. Just my thoughts
  13. #688
    Here is another of those horizon things - I took the horizontal line on the building that is at the base of the control tower - it's attached to the control tower - but - I guess not - where would other take the line for the horizon??
    http://www.jetphotos.net/viewreject_b.php?id=2991914
  14. #689
    Last time I saw a tower like that, Mark, I was in Pisa I would run a vertical down the side of the tower and see how that looks.
  15. #690
    Pennsylvania
    Can someone help me rotating this one? I can't find what would be the horizon.
    http://www.airliners.net/procphotos/rej ... esized.jpg
    Also, this was rejected for being dirty behind the rotors, but I think it's the clouds that give that affect. I equalized the image, and there are no dust spots behind the rotors.
