Page 43 of 92 FirstFirst ... 3339404142434445464753 ... LastLast
Results 631 to 645 of 1369
  1. #631
    Re: Post Your Recent REJECTIONS!
  2. #632
    Quote Originally Posted by heeshung
    http://www.jetphotos.net/viewreject_b.php?id=2727834
    Mark, me thinks you should have uploaded using all of the info you would use for a regular aircraft shot, and then checked "wing shot" off.
  3. #633
    Maybe they want you to upload it as a "wing view" with the data of the aircraft you were flying in?
  4. #634
    Quote Originally Posted by wunaladreamin
    Yeah, apparently so. I looked through the database and some airport overview photos had part of the engine and/or wing. I figured that since the main focus of the photo was the airport I'd put it as the subject.
    I reuploaded with the details of the plane.
  5. #635
    Here's one for grainy. I obviously know it's a little grainy, but it comes with this shot...it's a moving aircraft at night, after all!
  6. #636
    I personaly dont entirely see how this is undersharpened(soft)
    If anyone sees it is whats the best way to fix this minor problem?
    http://www.jetphotos.net/viewreject_b.php?id=2751283
  7. #637
    Quote Originally Posted by Delta777LR
    It's a bit soft Sergio. Add more USM to the plane and a little more contrast to the image.
  8. #638
    "Part of Aircraft Cut Off"
    Well, obviously...but I cropped it this way deliberately.
  9. #639
    Moose on a rejection like this, I believe that the part they are referring to is the forward-most rotor blade. I think if that one blade was "all in" they would accept.
  10. #640
    Jul 2006
    Albany, NY
    Perhaps these aren't perfect, but I thought that they had a chance. I can't figure out why the registration number in the southwest shot got a bit smudged while the rest looks okay.
    http://www.jetphotos.net/viewreject_b.php?id=2759715
    http://www.jetphotos.net/viewreject_b.php?id=2759704
  11. #641
    Moose its an odd crop, it just looks unfinshed.
  12. #642
  13. #643
    Maybe someone can help me out here
    1 Digital Manipulation, what do they mean by this?
    http://www.jetphotos.net/viewreject_b.php?id=2762282
    2 Undersharpened
    http://www.jetphotos.net/viewreject_b.php?id=2762269
    3 again undersharpened, also contrast
    http://www.jetphotos.net/viewreject_b.php?id=2745342
    What am I doing wrong with the sharpening, how much USM should be best or contrast??
    4 im not familiar about this, but this one was over processed, what do they mean?
    http://www.jetphotos.net/viewreject_b.php?id=2752960
  14. #644
    2 Undersharpened
    #1 - halos visible around the wings will get you the D/M rejection. Maybe too aggressive on sharpening or highlight/shadow tool?
    #2 - with the exception of the nosewheel the whole forward half of the aircraft looks flat.
    #3 - again the underside of the aircraft looks flat. If you tried to lighten the underside up you may have overdone it a bit, and it almost looks hazy to me. Combine that with the sharp edge at the top of the aircraft to the sky and I think that's where the contrast issue comes in. It's not consistant.
    #4 - The sky looks all mottled and grainy. The white seems to be a bit overexposed as well, surprised they didn't mention that.
    As for USM settings, there is no absolute number, it will differ depending on light conditions, type of lens, etc. Just watch out for jaggies, but make sure things appear clear. Haziness will lead to flat (undersharpened) images.
  15. #645
    Quote Originally Posted by lijk604
    And yet I had this accepted last year - I guess it depends on the screener...
