Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
Thread: Bomb Scare LGA This Morning
  1. #16
    Re: Bomb Scare LGA This Morning
    If you think there might be a live bomb in the terminal, why would you NOT evac? You want to keep them there?
  2. #17
    Apr 2009
    KCLT
    Phil:
    You most likely(being in NYC) have much more info than I. Maybe I should re phrase. If the supposed bomb was found in which ever terminal, why would you evacuate the concourses also rather than just the area where the supposed bomb was found?
    Train as if your life depends on it. Because some day it may.
    Opinions expressed are my own & not those of my employer.
  3. #18
    I would jsut think to get everyone out so tha tyou don't have peopel trapped in the concourses if something happens in the terminal area. I see your point though.
  4. #19
    Middle Village
    The TSA Behavioral Detection Officer and the TSA Officer working at the Ticket Document Checker position recognized the person was acting strangely then the box attached to his duffel bag was noticed. PAPD was called as per protocol. When the officer arrived, the suspect began reaching around the bag and the officer took the quick action of subduing the suspect and separating him from the bag. As the bag had switches and wires attached the decision was made to immediately evacuate the area.
    Some of the things you need to keep in mind is even though the suspect was removed from IED this doesn't mean the device could not be detonated. There have been incidents where a suicide bomber has went to back out and a spotter was in the area to remotely detonate the device.
    The bomb squad examined the device and couldn't rule out it being legit or not so it was disrupted. There are several reasons why the evacuation would extend to the entire terminal. Dependant on the size and makeup of the possible explosive the recommended safe zone is 1000 feet. Also there is a possibility of chemical, biological or nuclear agents being within the device (your dirty bomb).
    There is an issue with evacuating people and herding them outside. I have run and been involved with tabletop exercises and this is always discussed. The passengers were correctly evacuated away from curbside and the glass frontage. There was a searches for secondary devices and a heightened awareness within the groupings of people. With the amount of people that need to be evacuated this is always a concern.
    Ronald Reagan
  5. #20
    Makes sense. Thanks for the insight.
  6. #21
    Apr 2009
    KCLT
    I can understand evacuate the area, but dump the terminal or terminals where people are already safe makes no sense to me. IMO PAPD got this one wrong. As I said earlier had this been a set up now you have the massess out there to light up the real thing. Multiply this by 3 or 4 airports & 9/11 will look like nothing.
  7. #22
    Middle Village
    Quote Originally Posted by coachrowsey
    You are new on the board so you don't know all the players here. Let's just say I am not speculating, I am directly involved in these matters. I have been in Emergency Management most of my life and am at LGA. In the situation such as this, securing in place is not really the option. I understand your idea of just evacuate the C concourse, but we are not talking about just blasts anymore. There are other possibilities such as CBN and if there was an explosion, the panic of the passenger would be tragic then people would be second guessing why the terminal wasn't evacuated. Just from a blast, the percussion would cause shrapnel from all the wonderful glass and metal the terminal is made of. The evacuation usually is just to the local area then it is up to the bomb squad on if they want to increase the safe zone. Since the Bomb Squad disrupted the package they want the room.
    The risk of the crowds is known but the incident commander needs to weigh the risks. Something you never want to be in the position to do.
    Ronald Reagan
  8. #23
    Apr 2009
    KCLT
    But again, you evcauted all those people that were safe out to where ever you moved them to. Now you have the massess light the bomb. Which is worse ?
  9. #24
    I think the other point to keep in mind, from a crowd management standpoint if PAPD needed to further move the people farther away from LGA its easier if everyone is in one central location. Think about if they kept the people in the piers and something did go off and cut them off. You'd have people here and there with perhaps limited support to help them in those blocked off areas. I was at ISP in 2002 when there was a bomb scare, they moved us to one central parking lot. Of course a bomber could be within the crowd and set something off, that's impossible to know, you weigh your options and risks.
  10. #25
    I am sorry but I dont get what you are saying? Maybe I'm dense here. Are you saying they would blow up the people out where they evacuated to?
    And how exactly were the people safe in the terminals? The authorities had no clue if this device was real, if this guy was a legit
    terrorist or just a psycho and if there were any other devices or perps in other parts of the terminal.
    PAPD did the right thing here. I believe protocol in any explosive device situation is evacuation as far as possible.
  11. #26
    Apr 2009
    KCLT
    Quote Originally Posted by Gerard
    Let me see if I can be clear. The psgrs on the concourse or courses have all ready been screened(although that's questionable) the perp was taken down. Now you dump the concourse or concourses you have all these people piled out there together. Now if this had been a diversion(thank God it wasn't) a terrorist or team sets off real explosives among all these people that have been dumped from the sterle area.
  12. #27
    i don't seem to follow what you're looking for. the decision was made by the people on the ground, the people that are trained to do what they do on a regular basis. sitting here now tearing it apart is donig nothing more than wasting time.
  13. #28
    Middle Village
    Don't know what you imply by the "although that's questionable" comment. Yes, they are clear but that doesn't mean they are safe if there was an explosion. Yes, the diversion situation is there (I think I have said this three times already). You are damned if you do, damned if you don't but for control of the terminal and the safety of the passengers they are sometimes better off outside. Like Matt said, it is the people with boots on the ground to make that decision. We go through exercises all the time and I am usually the one bringing up your concern of the herding effect. I understand it but it is the particular incident that affects the decision. All the Monday morning quarterbacking doesn't do anything.
    Ronald Reagan
  14. #29
    >Let me see if I can be clear. The psgrs on the concourse or courses have all ready been screened(although that's questionable) the perp was taken down. Now you dump the concourse or concourses you have all these people piled out there together. Now if this had been a diversion(thank God it wasn't) a terrorist or team sets off real explosives among all these people that have been dumped from the sterle area.[/quote]<
    I still believe the authorities did the right thing. Protocol is to evacuate and history of such incidents here in the US is that bombers
    attack structures. Of course the fear of suicide bombers in crowds of people which happen with frightening frequency in Iraq, Pakistan,
    India, Israel etc is on the minds of those in command and I can guarantee (Right EMSHIghway? :) )they are prepared for such a
    scenario but they reacted correctly according to their training.
    Maybe if suicide bombers in crowds happen here they will react differently. For now..........
    BTW if that ever happened here God Help Us All!!!!!!!!
  15. #30
    My thought is - at the end of the day, you want the people in the safest place. If something happens in the terminal, explosives and buildings tend to cause a lot more problems than if people were outside. If you get everyone outside and then something happens, that unfortunately is out of the hands of the people controlling the situation. If you herd them inside to a "safe" location, who knows what might happen to the building. Isn't that why lockers were removed from the insides of terminals? In case of something happening in the lockers?
