Page 14 of 92 FirstFirst ... 41011121314151617182464 ... LastLast
Results 196 to 210 of 1369
  1. #196
    Re: Post Your Recent REJECTIONS!
    Mario, the flag on the tail. I got hit with the same type on the same paint scheme into JFK.
  2. #197
    http://www.airliners.net/procphotos/rej ... 39U-bk.jpg
    And another. I dunno., I'll back off, but I find that with Anet, I'm getting rejected for either sharp or soft. I can't win.
  3. #198
    Mario the two shots you posted are oversharpened big time. Here is my shot from that day of the 727. I purposedly did a little less sharpening and figured the subject would make it easier to get in.
    http://www.airliners.net/open.file/1167738/L/
    On your Emery you have jaggies all over the place and the overall look is way overdone. Back off a bit. The light was perfect when we shot at Ikea so you shouldn't need much USM.
  4. #199
    This photo was pretty much DOA out of the camera, but I'm a big fan of the T-6, so I took a stab. It was donked for the contrast - anything more and the sky behind gets totally blown out. Oh, well.
    http://www.jetphotos.net/viewreject_b.php?id=1531974
  5. #200
    DTW
    Ugh,
    Categories wrong or missing
    http://www.jetphotos.net/viewreject_b.php?id=1536858
    Comment: cargo category needed
    Over Processed / Bad postprocessing
    Dirty Scan / CMOS Dust spots
    http://www.jetphotos.net/viewreject_b.php?id=1536854
    Comment: Halos (WHAT? Can someone help me here with what the screener ment?) Can someone also show me where the dust spot is because I could not find it, I just tried every trick in the book (it doesn't help that my screen is dirty though)
    http://www.jetphotos.net/viewreject_b.php?id=1536857
    Again, can anyone spot it?
    nwa FOREVER!
  6. #201
    The last two photos are great, I see no dustspots.
  7. #202
    I think I see one above the Delta title 6 windows back or so. Looks big too. As for the overprocessing after I equalized it I see this big mess at the bottom left corner where it looks like you went ape with the spot healing brush. Use clone stamp to clean dust spots. Also clean your camera so you don't get them.
    Also if you equalize it the halo is clear as day.
    As for the Delta 757 you have a huge dust spot in the upper left corner right against the border.
  8. #203
    DTW
    Alright guys, I saw it now.
    My button must have gotten stuck by accident (hence the "ape" usage of the spot brush)
    Saw the halo too, what causes that/what can I do about it?
    nwa FOREVER!
  9. #204
    Here's a helicopter shot from Pocono
    - Horizon unlevel (Soft also)
    http://www.jetphotos.net/viewreject_b.php?id=1538048
    I knew this would be a tough shot - there isn't really anything I can see to level it. The copter isn't level as it comes down to land, the race track in the background angles away from you, so the wall and building behind it aren't really straight as you view them, and the campers in the infield are at all sorts of angles. Any ideas, or does this stay in the personal collection?
  10. #205
    Halos appear when you use USM improperly. Check the radius you are using. If it's too much you will get the halo effect.
  11. #206
    The Netjets scheme isn't easily rescued. Even before sharpening, it was starting to get a case of the jaggies. I'll take another stab at this one.
    http://www.jetphotos.net/viewreject_b.php?id=1543315
    The lighting conditions were tough - I was hoping a good composition and the uniqueness of the Osprey would help, but I guess not. The levels on the haze grey body are about as high as they can go before the sky becomes a blinding white blob.
    http://www.jetphotos.net/viewreject_b.php?id=1543386
    Bad framing. It's 117 pixels from the top of the winglet to the edge, 130 pixels from the lowest point on the wing; 9 pixels on the left, 16 pixels on the right. I'm not whiny enough to appeal, but it's not worth the effort to re-edit, either.
    http://www.jetphotos.net/viewreject_b.php?id=1543448
  12. #207
    For the AS plane I just think it's too high in the picture. Everywhere else looks fine.
    "lol retart"
  13. #208
    Mateo I think you can save all three of those, the bizjet just needs to be sharpened less, all biz jets will have jaggies in the cheatlines. When you sharpen it just watch the edges for jaggies to appear. The Osprey I think can be corrected using levels pretty easily and again just watch the sharpening. The AS is an easy fix but again all three can be redited and sent back up, not bad shots at all.
  14. #209
  15. #210
    Scottsdale, AZ
    Quote Originally Posted by Iberia A340-600
    Gordon, I think your 707JT shot is great. I am a little surprised it was rejected solely for "clutter" when all that is present besides the plane are a couple of cones on the ground and the stairs at the front door. I have seen pictures on both a.net and jp.net with both cones and stairs present in the picture.
    That being said, on my screen there appears to be a very slight blue cast in the picture. If you fix that, I'd try uploading to a.net.
    Great job on that picture.
    Josh
