Originally Posted by
megatop412
Lucas- night spotting is pretty much restricted to static aircraft as most cameras are unable to take any kind of sharp shot of a plane in the air in darkness. See the recent thread about the Yemenia 747SP to see what I mean.
So...if you can get yourself into a position where you have a clear view of a plane on the ground at night, set up your tripod(you have a tripod, right), set the camera to base ISO(200 on the D70), set yourself to P mode(you can progress to S, then M as you get the hang of how to juggle the exposure around), no flash is needed, and start shooting. Get in the general ballpark to where it looks sort of OK, then make your adjustments to make it better. Optimally you would use a cable release to fire the shutter but if not, use the camera's self-timer. If you don't have a tripod you at least need a surface for the camera to rest on, you cannot handhold for most night shots. Yes you can turn up the ISO but like I said earlier you don't want to go above ISO800 on the D70. Even at ISO800, your shutter speeds will still be too long to get a sharp shot unless you're on a tripod or have the steady hands of a surgeon.
Some of the folks here have excellent panning skills and can follow a moving airplane precisely enough to get a sharp picture even at night. That ain't me though.
A final note: yes some people use flash for night shots, but those are usually shots where you have permission to be close to an airplane and can use remote flashes or strobes on stands to paint the plane and get an interesting exposure. I don't think that's what you meant about using flash- your onboard flash won't cut it.
