Sorry, I rounded off. It actually weighs 8.35 lbs to the exact weight is 50601 lbs.
"The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' "
Ronald Reagan
After some research, that excavator is a Liebher R9800, with a shovel capacity of about 42 cubic meters.
http://www.liebherr.com/me/en/produc...106220!11929-0
(earlier error corrected)
1 cubic meter = 1.308 cubic yards
(42 cu. m)(1.308) = 54.936 cu yds
(202 gal/cu yd)(54.936 cu yds) = 11,097.072 gal
(8.35 lbs/gal)(11,097.072) = 92,660.551
:D
Shoot first, ask questions later.
dfalk.smugmug.com
Your math is wrong because you said 47x1.308, but you earlier quoted the Liebher as holding 42 cubic meters. Where'd the 47 come from?
103,000 lbs sounds a bit high though.
The numbers seem astronomical to me, but if it is indeed 42 cubic meters, I come up with 92,075 lbs of water.
Email me anytime at [email protected].
An average household pool that's 24x16x4 holds about 11,500 gallons of water, and size-wise, that scoop looks about right. So maybe the numbers work.
Keep in mind, the Evergreen Supertanker can carry 20,000 gallons, at a liquid paylod of 167,000 lbs.
Oh snap, Phil has got his geek-on.
.....when I wrote it out on scratch paper, my two looked like a seven....grr...you're right...
dfalk.smugmug.com
what have i done? speaking of geek, who know how to convert fuel from pounds to gallons and vice versa, without calculators?
always cross out sevens and zeros...Originally Posted by GrummanFan
Don't let Phil fool you, he was a loadmaster & is a Dispatcher, he speaks geek, fluentlyOriginally Posted by mirrodie
“The problem with socialism is that you eventually,
run out of other people’s money.” - Margaret Thatcher
Originally Posted by cancidas
LOL! Some of us used to work for FBO's that were too cheap to give us calculators :mrgreen:
EVERYONE IS THERE TO SEE THE SHERPA!
