Not a lot happening, but I did see this interesting KingAir A100 - looks like it has a camera located in the rear underside of the fuselage - surveying aircraft?
email: [email protected]
[quote="MarkLawrence"]Not a lot happening, but I did see this interesting KingAir A100 - looks like it has a camera located in the rear underside of the fuselage - surveying aircraft?
INTERESTING CATCH!
It looks like a a cam or IR sensor gimbal to me.
Found that it is registered to Dynamic Aviation which sells and outfits a/c for "Intelligence, Surveillance and Reconnaissance, Airborne Data Acquisition"
http://www.dynamicaviation.com/
http://www.dynamicaviation.com/brochure_n15l.pdf
Chris,
Confederate Air Force Life Member
Flight Engineer, B-17G Flying Fortress "Texas Raiders"
http://WWW.AV8PIX.COM, an ICAS member
Where can you go spot at PBI?
Jordan Greene. - Happy Jetting
There is a public park on the south side of the airport just off the perimeter road - right next to Grumman - easy to shoot over the fence. If you need a better explanation - let me know and I'll get directions or a map together.
