Page 37 of 92 FirstFirst ... 273334353637383940414787 ... LastLast
Results 541 to 555 of 1369
Thread: Post Your Recent REJECTIONS!
  1. #541
    Washington
    Re: Post Your Recent REJECTIONS!
    I didn't see any fence in there - but I didn't run an equalizer on it either. I do see what appears to be a dust spot though.
  2. #542
    Quote Originally Posted by jerslice
    I see it now, its not very obvious with a quick look. Look at the discoloration on the left side of the pic, its a dark tint on the grass and nose.
  3. #543
    Washington
    Huh...I definitely didn't see that either at first - and actually just spent the better part of 5 minutes scoping it out. I do see it, and I think with an equalizer run it would be more obvious. Am I crazy or is there a dust spot in the top left corner?
  4. #544
    Since we've been discussing it so much, I did save and equalize it, and you can see the difference.
    Yes on both parts :D
  5. #545
    Washington
    Alright, I'm pretty sure I'm not crazy - top left, about 2 inches over and 1 down:
  6. #546
    Well damn - I missed that too...ok...so it was a failure...LOL...already looking at which one to edit next....
  7. #547
    Washington
    Amazing what you don't notice sometimes. I can't believe some of the stuff I miss sometimes.
  8. #548
  9. #549
    On the first and third shots, the sky is very noisy. Did you deselect the sky when sharpening? Almost looks like they were dark and you bumped the exposure too much.
    On the second one, the AA MD-83, the landing gear is behind the side of the overpass - that's always going to be a killer. It's an interesting shot, but unfortunately you can't cut off parts like that - maybe if you caught him a second earlier, before the gear go out of sight.
    On the last shot (you have the Pegasus shot listed twice) the white fuselage is blown out with no detail. White aircraft can be difficult to expose properly, especially with a dark background - you may want to dial in a little (1/3 stop) of underexposure, that may give you enough leeway to play with when processing without overexposing the fuselage.
  10. #550
    Washington
    Thanks for the tips on the rejects Moose - the reject reasons came as no surprise to me.
    I've run Neat Image on both of the Rainier photos but to no avail - I can't seem to clean them up to save my life.
    The Pegasus was one of two I threw into the queue and one made it. I agree though, it's completely blown out. I'll try adjusting the exposure in RAW.
  11. #551
    Washington
    You nailed it right on the head. And yes, I did deselect the sky when I sharpened it up. Like I said though, it doesn't seem to matter what I do. I ran neat image; I've selected out the sky, layered it and Gaussian blurred/despeckled/normal blur/noise reduction you name it; I've blur out some of the grain on the a/c itself and been as careful as possible with the sharpening. Those shots, which I like a lot, have been driving me up a wall to edit.
  12. #552
    Washington
    Accepted on a.net, rejected on jp.net. Jp.net is right though...
    http://www.jetphotos.net/viewreject_b.php?id=2382932
  13. #553
    Washington
  14. #554
    Can someone help me with this please....
    http://www.jetphotos.net/viewreject_b.php?id=2388998
    Dark/Underexposed? last time I submitted this shot it was overexposed
    Categories missing? I selected Military - is cargo missing on this - I'm not too sure?
    Bad Info: Registration - came directly from the USMC search engine that Moose provided - that one beats me a little - last time I submitted it, I didn't get the registration bad info.
    Ideas?
  15. #555
    Jul 2006
    Albany, NY
    Quote Originally Posted by MarkLawrence
    Ideas?
    Regarding overexposed/underexposed: I think you are a victim of relatively high sun angle combined with a high wing aircraft. The parts that have the sun glare are over exposed and the parts under the wing are under exposed. Not much that you can do about that :-(
