Page 2 of 92 FirstFirst 1234561252 ... LastLast
Results 16 to 30 of 1369
Thread: Post Your Recent REJECTIONS!
  1. #16
    http://www.jetphotos.net/viewreject_b.php?id=1360791
    Thoughts on this one? Was rejected for:
    - Bad Composition (bad framing / aircraft not centered)
    - Undersharpened (Soft)
    I'm concerned about the bad composition - I've gotten a couple of those lately, and I can't see what the problem is.
  2. #17
    Moose - absolute laymans look - too much air above the plane compared to underneath - that's what I've found when I've had those...
  3. #18
    San Diego, CA
    Like Mark said, it looks low in the frame and it might fit a bit better if you had a tad more space in the front and rear of the plane.
  4. #19
    John besides low in the frame what size are you cropping the photo to? The size looks to be on of those odd sizes. If you cropping to 1024, set your size to 1024x703.
  5. #20
    Quote Originally Posted by T-Bird76
    I'm using a 5 to 3 ratio, so it comes out 1024x614 - almost everything I've uploaded to JP.net has been that size.
    Usually for vertical centering, I put the center point of the crop box on the centerline of the fuselage (around window level) but with the size of the tail on this one, I tried to have similar spacing between the top of the tail and the bottom of the fuselage to the borders. Guess I'll go back and have another shot at that.
  6. #21
  7. #22
    Quote Originally Posted by Iberia A340-600
    Gordan that's an easy fix, just give the photo some CW rotation of about .8 and you should be fine.
  8. #23
    [quote=T-Bird76]
    Quote Originally Posted by Iberia A340-600":8b138]Un-level horizon
    [url="http://www.jetphotos.net/viewreject_b.php?id=1363007
    http://www.jetphotos.net/viewreject_b.php?id=1363007[/url]
    Gordan that's an easy fix, just give the photo some CW rotation of about .8 and you should be fine.[/quote:8b138]
    Thanks Tommy, I re-edited it and re-uploaded it.
    Got another rejection:
    Overexposed
    http://www.jetphotos.net/viewreject_b.php?id=1364347
  9. #24
    Moose, use either 3 to 2 or 14.45cm to 9.64cm. When resizing just put either 1024 or higher (depending on the quality) for the width and don't put anything for height, click ok and PS will choose the best height automatically.
  10. #25
    Am I missing something? This was rejected for "Jaggies"
    http://www.airliners.net/procphotos/rej ... 07_JFK.jpg
  11. #26
    Quote Originally Posted by lijk604
    I don't think you did, I would appeal that one.
  12. #27
    I see a TINY bit on the tail and side logos.
  13. #28
    Southbury, CT
  14. #29
  15. #30
