Results 1 to 7 of 7
Thread: Mario's guide to changing his oil! Pics!
    Ok, it was time to change my oil today and since I got a call from Mario it made me think. Let me make a guide for him on servicing his car since he bought the Altima He at least got the V6 so here it goes!
    Ok I want to direct your attention to a great website I belong to
    http://www.maxima.org
    This thread is awesome for what oil and filter to use.
    http://forums.maxima.org/showthread.php?t=227996
    I use Castrol 5W30 motor oil.
    As far as filters here is a pic showing three that fit our car.
    The small one on the left is the one our car comes with and is complete crap! It is too small and internally is made cheaply. Avoid! The one on the middle is the much better OEM filter. The Mobil1 filter on the right is the best filter you can use. It is 3 times bigger and has the best filtration of any filter made. It costs 10 bucks but it well worth it. I use both this and the better OEM filter (part#15208-9E000) You can get them cheap on this site.
    http://www.nissanpartsonline.net/ It is a great site for all your OEM parts.
    Ok warm up your car to normal operating temperature then shut it off and pop the hood. Remove the dipstick and oil filler cap. Begin with an organized work station.
    I also like to fill the new filter I am going to use with fresh oil.
    This is good because it helps your oil pressure build up quickly when you start the engine after the oil change. Pour some fresh oil in and let it absorb it then pour some more till the filter is full.
    Ok, chock a back wheel and break the lugs on the right front tire. Then jack up the car and remove the wheel. Before you continue on the oil change it's a good idea to check your brake pads by looking though the hole in the caliper.
    After this take note of the splash guard that blocks access to your filter.
    You simply remove this by using a small screwdriver to release the 4 small fasteners that hold it on.
    Notice the latex gloves I have on, they are great! They save you a ton of scrubbing your hands and nails. You can get them at any auto parts store.
    Now you can drain the oil, the drain plug is right beneath the oil filter. You need a 14mm box wrench to remove the plug. While the oil is draining remove the filter. I use a huge pair of channel locks.
    Spin the filter off and let that drain at the same time. In the meantime take note of the copper crush ring on the drain plug.
    I have placed a new one next to it. This needs to be changed every time you change your oil. Simply use a small screwdriver to remove it, or you can simply screw it off.
    Ok after you have installed the new crush ring you need to wipe clean the oil filter housing and lubricate the new filter with fresh oil. Then you can install the new filter and hand tighten only, do not use a wrench to do this.
    Then wipe down the oil pan and other areas that may have had oil spill on them when you drained the oil. Install the drain plug and snug it with your box wrench. It is now time to break out the torque wrench.
    Nissan recommends 22-29 Ft-Lbs for the drain plug. I use 27.
    Torque the drain plug and install tire and snug the lugs. Slowly lower car down and now use your torque wrench to torque the lugs. I use 80 Ft-lbs.
    Now it's time to fill the crankcase!
    Fill with 4 and a half quarts including the oil used for filling the filter. Start engine and park on a level surface. Shut car off and let sit for a while and check oil level. Also check for any leaks underneath. It is also a good idea to check all your other fluids as well.
    There you go Mario! Now you can change your oil so your cruising vessel lasts a long time! When I have to do my brakes I will post another thread for you!
    Nick you're engine is dirty!!! You don't use synthetic motor oil, and get your hands dirty man, take off those gloves!
    My Nik, I am forever impressed how organized your tools are.
    Oh and thanks for the play by play!
    Between this and your fascination with the moon photo, I am very scared.
    You have to take the tire off to change the oil? What kind of stupid design is that?
    And lose the silly rubber gloves - I have real mechanic gloves for working on the race car, but leave the rubber gloves to the doctor's office. Torque wrench? We don't need no stinkin' torque wrench!
    Quote Originally Posted by moose135
    That is a real pain when you have to take the tire off to service the engine. I had a GMC Jimmy for three years and when I went to change the oil or change the spark plugs on the passenger side you'd have to take off the tire, what a pain. My Altima is the same way as the Max. You know they do that so you say why bother I'll just bring it in.
    Without a lift it's much easier to just yank the wheel.
