Hi again,
I found out from past that the best time to spot at lgA is in the morning.
To the reg spotters at lga what are the setting you use on you camera if its a good day durning the morning at planeview park?(ex f stop, shute speed,)
Hi again,
Most of us shoot in Aperture Priority mode (usually called 'A' or 'Av'), and on a bright, clear morning at Planeview, f8.0 usually does the job. The camera will automatically select the shutterspeed so as to give you the correct exposure.
If you find your camera is giving you shutterspeeds too slow, open up your aperture (lower number), and if the speeds are too fast, make the aperture smaller (higher number). The camera will react accordingly.
Just experiment! There're no do-or-die rules written in stone. :)
Brian
