Seriously, anybody?
Seriously, anybody?
I'm on my monitor at work, but, it seems over-contrasty. The clouds were working against you so I'd say this is a personal collection photo, sorry Kenny.Originally Posted by wunaladreamin
http://www.jetphotos.net/viewreject_b.php?id=1964845
Reason: Heat distortion
I don't see any distortion on the AA jet. Thoughts?
Top and bottom edges of the white stripe, and really on the edges of all three stripes around and aft of the cockpit windows.Originally Posted by GothamSpotter
http://moose135.smugmug.com
That's not distortion, that's just the fuselage melting. :)
Far to much contrast. There's allot of noise in the shot to Kenny. The light just wasn't with you bro.Originally Posted by wunaladreamin
No its def blurry, you can see it in the wings, when its soft we check off soft ;)Originally Posted by adam613
http://www.jetphotos.net/viewreject_b.php?id=2004960
Over-exposure? Too much saturation?
email: [email protected]
The white is all blown-out, detail is lost in the upper fuselage.Originally Posted by MarkLawrence
As for the bad color...definitely. The bottom is more of an ocean blue, yours looks a bit "muddy".
Ok - Thanks John - I think I need to re-calibrate my screen....
http://www.jetphotos.net/viewreject_b.php?id=2014894
http://www.jetphotos.net/viewreject_b.php?id=2014885
Should I expand the top and bottom more? I'm just afraid that then the it'll look too far away. Or zoom in and then expand?
Mark, on the Blue Angels 4-ship, it definitely needs to be a closer crop, if you can manage that with the photo size you have. While the smoke trail looks nice, for the generally accepted "formulas" used by the usual aircraft photo sites, you need to cut some of that dead space.
On the second one, what aspect ratio are you cropping to? I usually use 4x3 or 3x2, which work well with JP.net's acceptable sizes. I'm assuming that is the issue - they said "Cropping / Photo edges / Size Ratio", and I don't see any bits in the corners/edges that got cut off when rotating to level then cropping. Check your crop ratio, and perhaps crop it a touch closer to the horizontal stabilizer on the right side - you should have about the same space to the edge of the photo as you do on the left side.
Thanks for the advice; I'll definitely give that a try.
I need some help with these.
http://www.jetphotos.net/viewreject_b.php?id=2018004
This got knocked for 1024x795?
I can see the soft spot in the front of the plane.
When I try to sharpen it up, i get jaggies on the plane. What do I do?
http://www.jetphotos.net/viewreject_b.php?id=2018009
Should I just sharpen it up a bit?
http://www.jetphotos.net/viewreject_b.php?id=2018007
i have no clue.
http://www.jetphotos.net/viewreject_b.php?id=2018006
Where is it unlevel??
"lol retart"
Yeah, me too.
Oversharpen. I thought it was still a tad soft in the nose.
http://jetphotos.net/viewreject_b.php?id=2017924
